December 6, 2022 at 5:21 pm
svafaei
SubscriberI am looking for an example to conduct CFD calculation for fluid flow in an open channel. For example water flow in an open channel.
December 7, 2022 at 5:28 am
SRP
SubscriberHi,
You can check this section of the user's guide: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/flu_ug/flu_ug_sec_mphase_using_steps_vof.html%23flu_ug_vof_open_channel
Also refer theory guide: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/flu_th/flu_th_open_channel_flow.html?q=open%20channel
Thank you
Saurabh
December 7, 2022 at 6:33 am
SRP
SubscriberHi,
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thanks
Saurabh
December 7, 2022 at 6:35 pm
svafaei
SubscriberThank you for the link. Can you lead me to a clip to explain the process for 3d open channel.
December 12, 2022 at 12:30 pm
SRP
SubscriberHi,
You can get tutorial for the 3D Open Channel. You may look up terms like Ansys 3D open channel in a search engine.
Please take a look at this discussion thread on the forum at https://forum.ansys.com/forums/topic/modelling-open-channel-flow-with-wave-at-the-interface/
I hope this clarifies 3D open channel flow for you.
Thank you
Saurabh
2726
2146
1357
1150
462
