Tagged: 2021R2, 2022-r1, fluid-flow, missing-tools-analysis-systems, workbench
March 12, 2022 at 8:21 pm
Felipe_P
SubscriberHi!
So, I installed Ansys Student 2022 R1, but the fluid flow was missing from the Analysis Systems, then to see if was anything worng I installed de the version 2021 R2 and in this version only the fluid flow was available.
Version 2022 R1:
March 18, 2022 at 4:18 pmGeorge Karnos
Ansys EmployeeI would recommend uninstalling all, then remove the Ansys Inc directory that exists under c:\Program files\
Then install2022 R1 from a fresh download:
Please let me know if this helps!
*Right-Click on setup.exe and choose "run as administrator"
March 22, 2022 at 12:58 amUniwite
SubscriberI have the exact same issue with 2022R1 and reinstalling doesn't help at all.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2684
2120
1349
1136
461
