August 18, 2017 at 4:38 pm
svecchi
Ansys EmployeeA viscous fluid is between two concentric cylinders of radii a and b, which are rotating at constant angular velocities. The diagram below shows these two cylinders and their respective angular velocities. In this problem, a=1[m] b=2a and 2=0 [rad/s] but the velocity of the inner wall must be calculated to create the Taylor-Couette phenomenon. Find the velocity vectors that are characteristic of the Taylor-Couette flow. See the attached file for the tutorial regarding this problem.
January 2, 2019 at 9:36 am
swathi
SubscriberCan you suggest me a better turbulent model that can be used? I find that only RSM model can be used. But I didn't find many tutorials for it.
January 21, 2020 at 5:07 pm
praveen98
SubscriberMadam, me too working on similar problem. Can u share any material if you had found any
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- Magnetics-Permanent Magnetic Circuit with Air Gap
- The project files directory doesn’t exist
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
- vibration
2646
2110
1337
1112
461
