Fluid flow through the nozzle
    • Sohanur Rahman
      I am trying to draw a 2D nozzle with the help of Ansys spaceclaim 2023 R1. I have drawn one side of the nozzle through equation. So when i am trying to draw another side, drawn one get vanished. I don't find any green tick to fix my already drawn portion. Then how do i draw the whole nozzle by using different equation at a time?
    • RK
      If the curve is same, you can just mirror the curve along the center line. If not, generate one curve, get out of the sketching mode and try generating another.
    • Sohanur Rahman
      Thank you. But i have tried these ways. Unfortunately, the drawn part get vanished whenever i am trying to draw center line to mirror the curve. Same thing happens when i am trying to get out of the sketching mode. How do i solve this problem? Another question is , is it possible to use the same equation to draw the curve in design modeler?
