August 14, 2017 at 4:55 pm
svecchi
Ansys EmployeeA developed, turbulent, steady flow enters through an inlet, passes over a backwards facing step and then reaches the ground. In this demonstration, an enclosure will need to be created around the step and air will be used as the flow material. This tutorial uses ANSYS AIM to plot the velocity vector and pressure contours. See the attached file for a tutorial on this problem.
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- Magnetics-Permanent Magnetic Circuit with Air Gap
- The project files directory doesn’t exist
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
- vibration
2600
2088
1319
1108
459
