Fluid post-processing measurement problems
    • JASOMCHANG
      I would like to ask you how to designate a point on a moving object in the post-processing of the fluid, and use this point to measure the parameter change of the object in motion.
      As shown in the picture, I want to fix several points on the fin to measure the pressure value that the fin changes at different times.
      I don't think you can, others may know a way. Simple option will be to split out one facet on the surface and monitor that. n
