September 17, 2018 at 7:39 pm
upot2
SubscriberHello,
I am trying to do a thermo-mechanical stress analysis on a file created in ANSYS Icepak. The Icepak file consists of a cold plate (with an inlet opening and outlet opening for water to flow through) on which a few heat sources are placed. The Icepak file works well and I am able to get a solution.
On importing this to Static Structural through Workbench, the temperature is mapped well. My question is how would I go about dealing with the fluid regions (coolant) in the model for a structural analysis? All other regions are solid and can be assigned structural material properties, however I am not sure what I do for the coolant, since it does not have properties like Young's modulus, coefficient of thermal expansion etc, typical to a solid. I have attached an image of the Icepak model for further reference (the grey shaded regions represent fluid flow with the unshaded areas around them representing solid material)
Thanks
September 17, 2018 at 11:04 pm
September 18, 2018 at 3:29 am
Sandeep Medikonda
Ansys EmployeeUnfortunately, this is not my field of expertise either peter. Although, I've reached out and will hopefully have something soon.
P.S: In the future, I think this question will get more traction in the Multiphysics thread.
Sandeep
September 18, 2018 at 3:50 pm
upot2
SubscriberHi Peter,
On suppressing the fluid body, would the space vacated by the fluid body automatically be occupied by the solid cylinder around it? This is something that should not happen since its basically a hollow cylinder with the inner radii occupied by fluid surrounded by a certain thickness of solid material. The whole region being occupied by the solid would lead to incorrect stress values.
However, I am not sure if this is what Static Structural indeed does on suppressing a fluid body. If anyone could explain this, it would be great.
Thanks
2066
1285
1096
459
