March 10, 2021 at 1:14 pm
Biharae
SubscriberI have been trying to do a CFD sim on a Compressor(Axial inlet). I can only find tutorials for linear pipes with a impeller or pipe but not for a pipe which has some kind of bend or outlet is on a different axis than the inlet. I want a help for the procedure (step by step will be very helpful) of what all steps to be taken right from designing, meshing and how to specify my fluid domain.
March 11, 2021 at 1:55 pmKarthik R
AdministratorHello,nI don't know if we have anything readily available for the exact problem you are modeling. Having said that, you will need to use MRF (Frame Motion) or Sliding mesh (mesh motion). There are several tutorials on YouTube related to centrifugal pumps and fans which might give you a good starting point. I don't think it matters whether you are simulating an axial or a centrifugal configuration. The model set-up is pretty much the same, as long as you define the appropriate inlet and outlet boundary conditions. nWe also have an axial fan simulation in one of our AIC Fluids Learning Track. It might be useful to learn and might help you set-up the problem.nKarthiknMarch 11, 2021 at 3:26 pmBiharae
SubscriberThankyou.. I'll look into the coursenViewing 2 reply threads- You must be logged in to reply to this topic.
2656
2120
1349
1118
461
