Fluid solid Interaction
    • anuragpme17
      I am doing Fluid solid Interaction coupled analysis. My analysis is converging but in solution information summary in system coupling, in mapping summary, data transfer from target to source is showing 0. I have attached the image of the mapping summary. If anyone knows kindly reply.       Thanks
    • Raef.Kobeissi
      How did you set the interface, more detail about the setup is required.
      Thanks
