Kampus Merdeka
Kampus Merdeka
Fluid Statics Blimp Buoyancy Result Problem
    • Kemal Firdaus Semendawai
      Why are my pressure contour results showing all black and not displaying any contours? What could be the possible reasons for this issue and how can I fix it?
    • Essence
      That is because the Min and Max pressure values is negative and positive infinity, respectively, which is not relevant. Try checking if you have setup the case properly or not.
