TAGGED: 2-way-coupled-fsi, transient-structural, workbench
September 28, 2023 at 2:55 pm
HB Z
SubscriberWhen I use workbench for fluid-structure interaction, the transient structure reports an error: "An unknown error occurred during solution. Check the Solver Output on the solution information for possible causes" , and no other errors are found, I find only one error in the file.err file, and the error in fluent is as follows: "Error : Invalid request method GetElementData for variable force", what could be the reason?
September 29, 2023 at 2:41 pm
Federico Alzamora Previtali
Ansys EmployeeHello,
when does this error occur? Is it right at the start of system coupling run? Or later during the run?
October 7, 2023 at 2:32 pm
HB Z
SubscriberThis error occurs at the beginning of the coupling
- A solver pivot warning or error has been detected
8770
4658
3151
1678
1456
