October 29, 2018 at 3:54 am
pcaicedo
SubscriberHello all,
I am running a 1-way FSI using data from Fluent (a steady state with MRF) and Mechanical. The objective is to calculate the required thickness of the blade. If I modify the thickness each time and compute CFD for each model, it will take me so long because the whole mesh has around 7 million cells, thus I would like to know if
1) I can use a surface of the blade that matches CFD and the model in Mechanical and import the pressure difference from Fluent, or
2) I can vary the thickness on Mechanical, and then import the pressure of the other side of the blade in that "virtual" surface?
You can see how the pressure is imported in the suction side, but I need the pressure difference using the pressure side too.
Kind Regards,
Paul Caicedo
October 29, 2018 at 5:43 pm
Sandeep Medikonda
Ansys EmployeeMoving to the Multiphysics Category, so that it might get more traction.
2524
2066
1285
1096
459
