Fluid structure interface Error
    • abdoomer199
      I am trying to make system coupling between transient and fluent modules, But I can not make the fluid structure interface between them
      What can I do ?!
    • Ashish Khemka
      Hi,nnPlease see if this link helps:nnArraynRegards,nAshish Khemkan
    • abdoomer199
      Thank younPut I do not know which side to select in Fluid solid interface ?!nn
    • abdoomer199
      But*n
    • Kai
      Hi, the face you selected is not valid for some reason, so the row is highlighted in yellow. It is hard to tell why it is not valid just from the image. Try click Show Error icon under Home tab and see if it tells more info. Also, make sure the face is not sharing topology (share nodes with other faces).n
Viewing 4 reply threads
