Fluid-Structure Problem Post processing
    • sunny.sihag96
      I am using ANSYS 2021 R2. I am working on Fluid-structure interaction problem, but I am unable to drag the solution module of Static and Transient Structural to the separate Result where I can post-process this along with Fluent result. Please guide me how to proceed with this. I am also sharing as screenshot for the same.
    • Murari Iyengar
      Since you have already connected Fluent solution cell (B5) to the setup cell of Transient Structural (C5), you only need to connect Solution of Transient Structural (C6) to the results. You can also directly check results in C7 which will have accounted for the Fluid Flow results in your Transient Structural case.
    • bhagwantP
      Hello sunny.sihag96,
      For additional reference to above comment you can check one sample case study eloborated over here:
      ">How to transfer a thermal field from Ansys Fluent to Ansys Mechanical? - YouTube
      Thanks
  • bhagwantP
    Looks like link is not working. Resharing:
  • Viewing 3 reply threads
