July 11, 2019 at 3:18 pm
Goenitz
SubscriberHi all,
I am trying to use fluid viscosity in CEL expression to be used in other formulai.
My material name is 'MSR' and fluid name is 'my'.
I am trying to write expression my.viscosity or my.density, but receiving this error.
P.S. 'my' is Fluid and Particle definitions and Solid definitions is 'Ni foam'
WARNING
Expression 'phasedensity*Cf/sqrt(Kp)' depends on a variable 'my.Density' which does not exist.
WARNING
Expression 'porosity*my.density+(1-porosity)*Ni foam.density' depends on a variable 'my.Density' which does not exist.
WARNING
Expression 'my.viscosity/porosity' depends on a variable 'my.Dynamic Viscosity' which does not exist.
July 11, 2019 at 4:12 pm
DrAmine
Ansys EmployeeIf single phase just use the variables without fluid names. -
July 15, 2019 at 3:14 pm
Goenitz
SubscriberThe MSR is mixture of gases of methane steam reforming reaction plus passing through a porous medium (Ni foam). Temperature is high so all gases are in gaseous state but Ni foam is in solid state. So it is not a single phase. I wrote expression on following parallel ground of CFX reference guide.
15.2.12.1. System Variable Prefixes
In order to distinguish system variables of the different components and fluids in your CFX model,
prefixes are used. For example, if carbon dioxide is a material used in the fluid air, then some of the
system variables that you might expect to see are:
• air.density - the density of air
• air.viscosity - the viscosity of air
• air.carbondioxide.mf - the mass fraction of carbon dioxide in air
• air | water.surface tension coefficient – the surface tension coefficient between air
and water
• air | water.area density – the interfacial area density between air and water.
July 15, 2019 at 3:48 pm
DrAmine
Ansys EmployeeYou are referring to the correct passage. Air in the example is a multicomponent phase.
3778
2587
1831
1242
598
