Fluidized bed velocity (CFD-DEM)
    • ChanonB
      I'm running a bubbling fluidized bed model using Psuedo 2D CFD-DEM. I have some question about my condition. I want to simulation the 200 micron particle's packed bed in this model which I created by injection file. This file shows the parcel diameter is 2500 micron. I want to set the velocity inlet which calculate based on Archimedes number. What the value of diameter that I must calculate to find the velocity, particle diameter or parcel diameter ?
      Thank you
      Chanon B.
    • RK
      Using the Archimedes Number, usually particle diameter is used to set the minimum fluidization velocity.
      Rahul
    • DrAmine
      Harnby, N; Edwards, MF; Nienow, AW (1992). Mixing in the Process Industries (2nd ed.). Elsevier. p. 64.
