March 19, 2022 at 11:20 am
sampathkumar
SubscriberI observe different flux densities in the plot and values. I mean in the plot 2.6T is maximum and in the values, it is not. Which is correct???..... May I know the reason for this?
March 23, 2022 at 8:39 amNavya C
Flux density results are shown only for the predefined variables and locations.
But the max flux density in your model seems to be at the rotor bridges which is not given in the variables but is shown in the scale.
Both are correct it is just that where the flux density is maximum on your design is not shown in the flux density variables. Also for the rotor bridges, we want them to be saturated.
For example, I ran an example model as shown below (here the peak flux density at stator back iron(which is predefined) is matching with the results)
Regards Navya
March 29, 2022 at 8:50 amsampathkumar
SubscriberThanks a lot for your response
March 29, 2022 at 9:00 amsampathkumar
SubscriberHello all In the flux density pattern that I attached the flux density in the rotor bridge is saturated....May i know how to overcome it
March 29, 2022 at 11:51 amNavya C
I didn't understand why you want to avoid saturation of the rotor bridges?
If they didn't get saturated all the flux will be confined to the rotor only. If you still want to avoid that just increase the thickness of the bridges.
Regards Navya
Viewing 4 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2726
2146
1357
1150
462
