August 9, 2023 at 8:44 pm
Brian Schlagenhaft
SubscriberHello. I have a parametric setup that is being analyzed. I am trying to show the flux lines as a field, but the only option I have is H, B, J. How do I show the "A" field or the flux lines?
August 10, 2023 at 4:21 pm
August 10, 2023 at 6:46 pm
Brian Schlagenhaft
SubscriberIf I select the streamline option, would I get the complete path of the lines?
August 10, 2023 at 7:11 pm
GLUO
Ansys EmployeeIt depends on your application and settings. Please go to Tools>>options>>general options>>reporter>>fields reporters>>streamline plot to adjust the settings for the streamline you want.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7626
4456
2955
1427
1322
