March 5, 2021 at 5:36 pm
Cesar0103
SubscriberHi everyone!!!
I'm simulating a synchronous reluctance motor and I need to get the flux paths for the direct and quadrature axes, that's, obtain flow paths for the excitation of the direct and quadrature axes...in the same way to be able to obtain the flux density in the d-q axes and the magnetomotive force.
In case someone has worked this problem could indicate some kind of procedure, I'm new to ANSYS and it's my first project using the software.
Best regards,
Cesar Gallardo
March 8, 2021 at 9:31 amNavya C
set up current excitations to windings such that the windings are excited when the rotor direct axis is at the center of a particular phase winding arrangement and plot the B fileds in that condition.
Similarly setup the current excitations to windings such that the windings are excited when the rotor quadrature axis is at the center of a particular phase winding arrangement and plot the B fileds in that condition.
This can be achieved by adding an addition angle (say delta) in your phase current equations. Generally for reluctance motors (with no permanent magnets) these angles are 0 degrees and 45 degrees.
Suggest you study more theory on this topic to understand better.
Regards
Navya
March 9, 2021 at 1:32 pmCesar0103
SubscriberHi!!! Thanks for your quick answer....
Regards Cesar
- Maxwell, HFSS or Q3D?
- Error
2684
2124
1349
1136
461
