August 22, 2022 at 6:56 pm
parth144
SubscriberDear all,
We are trying measure a drag coefficient of the vehicle using ANSYS 2020R1 version and comparing with the experiment results.
Question: When we use "Flux type: Rhie-Chow: distance based" and "Flux type: Rhie-Chow: momentum based", it provides differnet value of drag coefficient. "Flux type: Rhie-Chow: distance based" provides drag value of 0.58, while "Flux type: Rhie-Chow: momentum based" provides drag value of 0.38. it should not affect that much in the value. Why I'm getting two different values here? This option in "method" section was not there in previous ANSYS versions like 2020R2.
Thank you in advance for the help and support!
Regards
August 23, 2022 at 9:51 am
Danica
Ansys EmployeeHi,
Have a look at the following link for information on the different flux types:
32.3.2. Mass Flux Types (ansys.com)
Would also check mesh resolution to make sure you've resolved boundary and wake flow.
August 25, 2022 at 5:14 am
Nikhil Narale
Ansys EmployeeYou may also want to have a quick look at this forum discussion: Solution Method – Flux Type (ansys.com)
Thanks,
Nikhil
2656
2116
1337
1118
461
