August 22, 2023 at 9:12 am
Muhammad Aditya Nugraha
SubscriberI have read several references on the internet. I just want to make sure if the references I've read are valid or not.
In static structural analysis, what is the fundamental difference between "Force" and "Remote Force"? How is the illustration of their difference in the real world problem? Big Thanks
Saya sudah membaca beberapa referensi di internet, di sini saya hanya ingin memastikan apakah referensi yang saya telah baca itu valid atau tidak.
Dalam static structural, perbedaan mendasar dari "Force" dan "Remote Force" itu apa ya?. Bagaimana ilustrasi perbedaannya jikalau diilustraikan dalam permasalahan nyata?. Terima kasih -
August 30, 2023 at 8:17 am
Jorge Auther
SubscriberEvery day, the UK49s Lottery holds two draws. The morning draw is called Lunchtime Results and the Evening time draw is called Teatime Results. -
September 1, 2023 at 2:04 pm
Raihan Lutfianto
SubscriberHi Aditya, that's a really good question. The main difference between Force and Remote Force is how you apply the force. In Ansys Mechanical, Force can be applied directly to the body, while Remote Force uses what so-called remote point, and this remote point can be adjusted (xyz coordinate).
Typically, we use Remote Force to represent a complete system, but we want to minimize the computational cost by not including some components in our FEM model.
You can also refer to this Difference between Remote and ordinary displacement/force constraints (ansys.com)
- The FLUENT application failed to validate the connection.
- simulation example o ring seal with fluid pressure
- “Pseudo Transient” Method
- how to enable PSEUDO TRANSIENT in ansys 2022 R2 version
- Brake Pad Analysis Simulation Problem
- can’t login to cloud acccess using the same email on the independent campus web
- Rosette Gauge Purpose
- Selamat Datang
- Meshing Problem in Helicopter Pitch Arm
- Lumbar Motion Simulation – Coding part
7742
4502
2961
1449
1322
