force-deflection full hysteresis loop
    • elhamasadi
      Modelling a square plate (surface body) using multilinear plastic material, undergoing a repeated pressure pulse as below and fixed support B.C. is applied to the four edges, I can not extract the hysteresis loop in a way I can read the permanent deformations after each pulse. I'm looking for some hints , please.
    • peteroznewman
      I hope you will find my post in this discussion to be helpful.nI hope you will find my post in this discussion to be helpful.nn
    • elhamasadi
      nActually yes!nI want to export the permanent deformations of the model after each load, but I'm quite a beginner and couldn't exactly find out what was going on!nDo you suggest to apply isotropic hardening to the material modelling? n
    • peteroznewman
      No, I suggest you use the Chaboche model. n
    • elhamasadi
      nShall I used Chaboche model besides my previous settings (multilinear isotropic hardening) or ignor the previous settings?n
    • peteroznewman
      Charboche replaces multilinear isotropic hardening.n
    • elhamasadi
      nShall I use the values used in the post you previously mentioned or find them somewhere else?nI want to model Al 5083_h116n
    • peteroznewman
      Use values that are for the material you want to use.n
    • elhamasadi
      nThank youn
Viewing 8 reply threads
