Force-Distributed Constraint do not satisfy Compatibility Condition
    • Clayton Parisey
      When performing an analysis and you run into force-distributed constraint errors what are some of the primary causes or ways to figure out the causes in your model?  Are there settings you can turn on to trouble shoot the issues?
    • peteroznewman
      Can you provide details of your model?  Images of of the geometry, the supports, the loads. What type of analysis, static, dynamic? Please show the exact error message text from the Solution Output file.
