force of a pin inside a ring
    • isacco83
      hi, @peteroznewman i would like to ask your opinion
      i have to apply the force of a pin inside a ring, the pin has the same diameter of the ring
    • peteroznewman
      nUse a Bearing Load to apply the force and select the entire cylindrical surface.nA Bearing Load applies force to the surface only on the compression side of the hole.nA Bearing Load applies the highest force at the center and has a cosine drop-off to zero force at +/-90 degrees.n
