Discovery Import
Discovery Import
Force on a body
    • keith
      When a force on a face (Force on face in Y-direction) or body (Total force in Y-direction) is calculated in Discovery Live for an internal analysis, I get an answer of zero. If I select a face of the fluid body that was automatic created, a non-zero force is given. What am I doing wrong? How do I plot a non-zero force on a body or face?
    • Naresh Patre
      Hello Keith Apologies for missing out your question. If you set the fluid as Smart fluid body, you should be able to see non zero force values on body or face. To set fluid body as smart, display the fluid volume from Structure tree. Then select any fluid face, right click and select "Set as Smart Fluid Body"
      • keith
        Naresh Patre  Thank you. That solves the problem.
