January 13, 2023 at 8:37 am
Awang Shahariffin Bin Awang Kechil
SubscriberHi, I'm doing a simulation and test validation for impact force plate. The problem now is that, the reaction force from simulation is not the same as the test. I want to know if I am modelling the force correctly. Picture below is the location of the sensor, in the model I make it as fix support, then I use it to capture the force reaction at Z-direction. In actual test, that is the location of the force sensor. Am I model it correctly or is there any other wat?
January 16, 2023 at 12:28 pm
SaiD
Ansys EmployeeHello,
Could you please provide more information by adding more images.
- Please show an image with the coordinate system. Which direction represents the z-direction?
- How are the boundary and initial conditions applied? Show an image with the scopes of the boundary/initial conditions, and describe them.
- What is the force reaction value you obtain from the simulation and what value is obtained in the physical test?
Thanks,
Sai
2120
1347
1118
461
