July 25, 2018 at 1:50 pm
Adisa
SubscriberHi, I have one physical question, I used one panel clip where I needed to determine force on one part when the clip will drop from other part.
The question is, if I use more then one panel clip, how much is the force which is needed for opening one part with clips from another. If for one panel slip need 100 N, If I use 2 panel clips will the force be 200N?
On this the post I posted the analysis with one clip.
https://forum.ansys.com/forums/topic/fill-up-the-curve-of-nonlinear-material/
How to include reaction force on contact.
Best regards.
July 25, 2018 at 1:56 pm
Sandeep Medikonda
Ansys EmployeeHi Adisa,
I haven't followed your previous question completely maybe Peter will be able to help, but can you see if this article helps?
Sandeep
July 25, 2018 at 1:58 pm
July 25, 2018 at 2:41 pm
2146
1357
1144
462
