Force Reactions in Random Vibration / Response Spectrum Analysis
    • Dave Whitley
      I'm getting the attached error message when trying to pull a Force Reaction from a Fixed Support in a Random Vibration & Response Spectrum analysis in Ansys Mechanical.
      Anyone know what's causing this?
    • Joshua Smith
      In the precursor modal analysis, did you set the "Nodal Forces" output to "yes"? If not, that probably needs to be changed, solution re-run for modal and then the random vibration analysis.
    • Dave Whitley
      I found out what was causing it. I was also getting another error that stated "Invalid characters were detected in the project and/or environment name". I had a & character and spaces in the .wbpj project name. I took those out and that fixed it. I am now able to pull Force Reactions from Fixed Supports in a Random Vibration & Response Spectrum analysis.
