Forced Response Mode Superposition Bug
    • Tayyip
      Hi Everyone,
      I got a problem about how to apply harmonic post results 'manually' in Ansys Harmonic Response Module. I have fan blade with a tuned structure. And I followed methods which are necessary such as
      -unsteady pressure mapping
      -determining resonance point by inserting a campbell diagram
      -applying aerodamping on structure etc.
      by using APDL commands.
      Yet, I guess there is a BUG (see the attachment) in the harmonic response post module when trying to show results manually such as frequency response. It doesn't work! And I guess this is happening when I use cyclic symmetric structure. It doesn't appear in the full model.
      Any idea how to figure this out?
    • Kai
      Hi Tayyip,
      This is a known limitation in MSUP Harmonic with cyclic symmetry. Setting up cyclic symmetric MSUP Harmonic in WB requires rather involved APDL commands and most post-processing (except for modal analysis) are only available through commands objects. Therefore, you have to use command objects to plot Equivalent Stress and Frequency Response.
      Thanks,
      Kai
    • Tayyip
      Hi Kai,
      Thanks for your response. So, is there any other way to map unsteady pressure distribution without using APDL commands. Because I have limited knowledge about commands and try to do this manually.
      Thanks,
      Tayyip
    • Tayyip
      Hi Kai,
      I have one more question;
      Is there any other way to map unsteady pressure distribution without APDL commands ??
    • Kai
      Tayyip,
      The key here is that running cyclic symmetric MSUP harmonic requires post-processing with APDL commands, so it is not about how you map pressure distribution.  You can try using Full Harmonic method which will not need APDL commands.
      Thanks,
    • Tayyip
      Hi Kai,
      Thanks for the answer. I didn't realize that I asked it double times, sorry.
      Have a good day,
      Tayyip
Viewing 5 reply threads
