March 19, 2022 at 12:24 am
jnelsen33
SubscriberI am using Fluent to simulate hurricane force winds on a home. I just realized that when I calculate values for force or lift, that the forces in negative directions are canceling forces in positive directions. Is there a way to set it up to take the absolute value of each face? For what I'm simulating , these forces would not cancel...they would both be pulling the structure apart.
Thank you.
March 21, 2022 at 11:46 amRob
Ansys EmployeeSplit the surfaces up so you report each one separately.
March 21, 2022 at 9:07 pmjnelsen33
SubscriberYes, that's actually how I was able to notice it, I named every face and solved by zone. I am confused by the way lift calculates any of these values. I strictly measured the lift on back side of my roof and got the value from Fluent in each direction separately, and then I found the overall lift that Fluent gives for the back side of the roof by selecting all vectors. The value isn't a sum of the three that I got and it's also not the magnitude, so I'm completely lost on how it's getting it's values. But I think we will have to split them up and use the absolute for each face and find the magnitude for each and treat them individually.
Thanks.
March 22, 2022 at 11:28 amRob
Ansys EmployeeRead up on the definitions in Fluent - then check what you're reporting and what any reference values are.
2706
2142
1355
1144
462
