November 27, 2019 at 2:02 am
JosiSandoval
SubscriberHi!,
I'm planning to use parameter correlation to study the pressure contact between parts when varying CAD parameters. My model has 4 parts, when they are in the nominal values the parts have full contact, but when I use the Parameter Set in the workbench to vary the dimension from the CAD model, a gap or penetration between some parts appears and I get an error when I apply the force cause it doesn't find contact between the parts.
I have tried to assure the contact in the CAD model using constrains but hasn't worked.
I have a restriction so I cannot use adjust to touch as interface treatment. So I have a applied a displacement (at the first strep before applying the force) to assure contact between the parts. I also set the pinball radius, but then I need to manually modify the displacement depending on the dimension of the gap.
Is there a better way to assure contact so I can just modify the parameters and run the simulation from the Parameter set, without having to open the model and change the displacement value.
I will appreciate any advice.
Thanks!
November 27, 2019 at 11:47 am
SubscriberWhat CAD system are you using? Most CAD systems are good at Assembly Mating Constraints. Stay in CAD until you have figured it out.
November 27, 2019 at 2:34 pm
JosiSandoval
SubscriberI'm using SolidWorks.
November 27, 2019 at 6:44 pm
SubscriberKeep working in SolidWorks. It has good assembly mating capabilities. I have SolidWorks 2019, though I am not highly skilled at it.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5162
3275
2453
