October 18, 2023 at 1:21 pm
ghamrawyk
SubscriberHello,
I am trying to model a forming process where a cylindrical structure with teeth on the outside penetrates a plastic pipe. The forming process is 45 seconds. The geometry is axisymmetric, so I set this from the beginning as 2D Axisymmetric. I've been having trouble running the simulation.
My questions are the following:
Is it possible to have some of the bodies rigid and other flexible?
If yes, when I change the body to rigid, a question mark pops up next to the body name with a menu containing an intertial coordinate system, could someone explain to me what is that and how to deal with it?
Should I use explicit dynamics or transient structural (quasistatic) in such simulation? Knowing that the geometry length is 300mm and the tooth size is 1mm. Mesh attached for just one tooth. The original problem has 200 teeth.
Is there an adaptive mesh option in Ansys to change the mesh around the tooth while penetrating the pipe?
I am attaching some screenshots of the simulation data. Thank you in advance.
October 20, 2023 at 1:11 pm
Ashish Khemka
Forum ModeratorHi,
Try running a transient analysis. An explicit analysis is generally used for short events (generally fractions of a second). Try a coarse mesh first and then you can try to refine the mesh further.
Ashish Khemka
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
