TAGGED: ansys-forte, forte, mesh, mesh-generation, tutorials
May 18, 2022 at 1:30 pm
k1124473
SubscriberHello there,
Should the Mesh Preview take over 4h to be created for Tutorial 5?
I have obtained the Tutorial 5 files from Forte>Help>Tutorials.
Are the files up to date and do they still work with latest Forte version? I'm using Forte 2021.
May 23, 2022 at 11:57 amMay 23, 2022 at 3:51 pmMay 25, 2022 at 10:16 pmRK
Ansys EmployeeCan you please check your CPU utilization to make sure there are no other processes taking up memory? Also, I would suggest you to upgrade to 2022R1, the latest version to see if this solves the issue.
May 25, 2022 at 10:23 pmMay 25, 2022 at 10:36 pmRK
Ansys EmployeeYes, this is right. What is the RAM?
May 25, 2022 at 10:37 pmk1124473
Subscriber8GB
May 25, 2022 at 10:42 pmRK
Ansys EmployeeTo my knowledge, 8GB RAM is low. Please check the min hardware requirements : Platform Support Data: Previous Releases | Ansys
May 25, 2022 at 10:53 pmk1124473
SubscriberI understand 8GB might be low. But with other errors I am having I think maybe its not the hardware. Maybe its the software. Maybe its the tutorial file/s. What do you think? Is there anyone at Ansys that can go through Fortes tutorial 5 or other tutorials and check that everything is working correctly. Id like to use tutorial 5 results for my project, but because I can not obtain them I have tried other tutorials and some worked but others showed different errors. Maybe the issues lie there somewhere? What do you think?
May 25, 2022 at 11:01 pmRK
Ansys EmployeeI will check the files and let you know if there is an issue. Please give us a few of days to test the files.
May 26, 2022 at 7:30 amk1124473
SubscriberThank you, RK. I really appreciate that.
Viewing 10 reply threads- You must be logged in to reply to this topic.
3744
2573
1817
1236
594
