Forte_bowl_geometry.stl
    • Haitham Al-Wakeel
      To simulate a case of (Dual Fuel Combustion) from (Ansys Forte Tutorials), it is required a file named (Forte_bowl_geometry.stl). I searched online, but could not find it.
      Please, can anyone provide me with this file?
      Thanks
      Is it not in the Help system?
    • Haitham Al-Wakeel
      No, it is not provided with Help system. However, may be it is available in another place.
      So, please can anyone provide me with the file named (Forte_bowl_geometry.stl)
      Thanks
      You are looking at this tutorial?  https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/forte_tut/i469650165101.html  The files are there and there is no stl needed.
    • Haitham Al-Wakeel
      Hi Rob,
      Thank you for your prompt reply,
      Yes, I am looking at this tutorial, but ithe first of all, it is required to (Importing the Mesh). So, how (or from where) can I import the geometry of Figure 3.1, please?
      Thanks
      I'll check, but my assumption would be you copy the relevent bit from the project.
    • Haitham Al-Wakeel
      Yes, please check this tutorial. I am confused how to start and I am waiting your answer. Thanks for your help.
    • RK
      You should see the .ftsim file in the tutorial, load the file into Forte, then go to Geometry and Mesh > Export Geometry. You will have a stl file.
    • Haitham Al-Wakeel
      Thanks RK for your advice (Import Forte project, and then Export geometry)
Viewing 8 reply threads
