November 29, 2017 at 6:43 am
Bogdan
SubscriberHello!
First of all I want to point out that I'm new to ANSYS Fluent (student) and I need some help to start with.
I want to determinate the shape and the height of a fountain jet with a certain nozzle at a certain flow (like the simulation below made with ANSYS Fluent).
Can I have some tips of what settings should I use for this? I need some help to start because the software seems really complex compared to Autodesk CFD which I used before.
Thank you!
November 29, 2017 at 3:23 pm
raul.raghav
SubscriberSince you mention that you are new to this, I'd really recommed you to go through the following tutorial to get a feel for the interface and the physics. The tutorial is for a 2D jet using Ansys Fluent.
Once you understand the above case, proceed with your actual geometry. Let us know if you have any questions, which you should have if you are doing it right
November 30, 2017 at 12:28 pm
Raef.Kobeissi
SubscriberYou need to use the VOF model which is a transient multiphase model, 2 materials will have to be assigned, Air and Water. You might need to add surface tension forces between water and air in addition to the gravitational force.
https://www.youtube.com/edit?o=U&video_id=73c4ojTW7Hw -
January 28, 2019 at 7:31 am
akban
SubscriberHi Raef Kobeissi,
Could you please suggest me how should I approach if the 2 materials are Water and Water. (Water jet in water). In that case, VOF model does not work.
Ayan
January 28, 2019 at 5:48 pm
Ansys EmployeeIf it's water in water then it's single phase, and should be covered in the basic tutorials attached to the documentation. Click on "help" in Workbench and have a read around the various section.
2726
2156
1359
1150
462
