Fourier vs Biot
    • prajput
      Can someone please explain what is Fourier number and how is it different from Biot number?
    • Keyur Kanade
      Hi @prajput ,
      Fourier number is a dimensionless group which arises from the non-dimensionalization of the conduction equation. It is a measure of heat conducted through a body relative to the heat stored. Fourier number characterizes the time scales in conduction problem. Biot number on the other hand is the ratio of the internal resistance of a body to heat conduction to its external resistance to heat convection. For more details on Biot number please check out the post related to lumped capacitance model on the forum.
    • prajput
      Sure, will do thanks!
