September 4, 2019 at 9:27 am
Abdoon075
SubscriberHello experts ,,,,,
I'm going to do a fracture analysis for stiffened panel by using shell element, but I can't complete the pre-meshed crack modeling because I have to select an "Edge" for crack tip when I just have a "Point" (which is the green point in the attached pic.) because the panel is shell element not solid element
please help me ...
September 4, 2019 at 4:29 pm
SubscriberYou have to use the Geometry editor to cut a Vee shaped crack into the edge of the sheet. Then you will have two edges that define the crack and a vertex at the crack tip.
September 5, 2019 at 9:23 am
September 6, 2019 at 1:26 pm
SubscriberI know a crack is supported in a 2D model, I don't know if a crack in a 3D shell models is supported.
Please get some experience using a pre-meshed crack in either a 2D model or a 3D solid model first, then you will know what success looks like.
You must create nodal named selections and you must create a coordinate system in the crack. Please read some ANSYS Help for more information.
September 6, 2019 at 4:03 pm
Abdoon075
SubscriberIn 2D model the crack tip must be a vertex, so the nodal named selection must be a point or a vertex. I tried 2D model and its work correctly. In 2D Model I must model the stiffeners as Line body, because in 2D analysis type I must draw in just only one plane (X-Y plane). In my case study I assume that the crack will propagate in plate and stiffener together, so I have to model a crack on the stiffener which I can't do if I model the stiffener as a line body. To eliminate the problem of modeling the crack on the stiffener I have to use 3D model. But When I use 3D I'll face the problem of creating the nodal named selection, because In 3D analysis the nodal named selection must be An edge at crack tip, but when I use shell element I have a point at crack tip
I read ANSYS help many times, but I didn't fine sol. for my problem
September 6, 2019 at 8:35 pm
David Weed
Ansys EmployeeHi, fracture analysis does not support shell elements, see here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/ans_frac/frac_parmcalcelemmatsupp.html
September 8, 2019 at 9:41 am
September 18, 2019 at 12:48 pm
Abdoon075
SubscriberDoes that mean shell element support the fracture analysis ???
October 4, 2019 at 12:04 pm
SubscriberShell elements do not support fracture analysis.
2120
1347
1118
461
