April 26, 2022 at 9:47 pm
Amith_Anoop_Kumar
SubscriberThe fracture parameters computed during solution may be incorrect. Check the Solver Output on the Solution Information object for possible causes.
What's the reason for this warning
April 27, 2022 at 12:48 pmRuturaj Gavali
Ansys EmployeeHey !
Check for the following:
A contact might have been created in the region of the crack contours.
A load might have been applied in the region of the crack contours that is not supported in the fracture parameter computation. Try replacing it with aDirect FEload. You can also replace the normal Pressure loads using theApplied Byproperty option,Direct.
Refer this link for more information: Solving a Fracture Analysis (ansys.com)
Thanks!
For more information, check out the following links:
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
April 28, 2022 at 6:55 amAmith_Anoop_Kumar
SubscriberRespected Sir/Madam I am not able to open these links
Also can you help how to resolve these isssue
A fracture result is specified by time instead of by set. If the time lies between two result sets, no interpolation is performed.Instead, there are two possibilities: (1) if there are no mesh changes, the lower set applies; (2) if there are mesh changes, the closest set applies.
Viewing 3 reply threads- The topic ‘Fracture analysis issue’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
