September 12, 2019 at 12:02 am
mekafime
Subscriber -
September 12, 2019 at 1:56 am
SubscriberThis is the force-displacement curve which says nothing about fracture.
I assume you have defined a material using plasticity.
The material has a property called elongation.
Fracture occurs when the Total Equivalent Strain > Elongation.
Plot Total Equivalent Strain vs Displacement.
Increase the force until the Total Equivalent Strain > Elongation then you will have reached fracture.
September 12, 2019 at 3:27 am
September 12, 2019 at 11:08 am
September 12, 2019 at 5:23 pm
SubscriberWhat is the Elongation material property for your material?
I wonder if the top graph has mislabeled axes? Isn't the vertical axis showing deformation in mm and the horizontal axis showing equiv. total strain?
September 12, 2019 at 9:44 pm
mekafime
SubscriberHi Peter,
A500 Gr.B
YS: 315 MPa
US: 400 MPa
23% Elongation
The graph was update.
September 13, 2019 at 12:13 am
SubscriberSince Elongation is 0.23 and Total Strain > 0.23, that means the simulation has gone past the point where fracture would have occurred.
September 24, 2019 at 3:35 pm
September 25, 2019 at 12:53 am
SubscriberIt's the maximum total strain in the model that is compared to elongation.
2066
1279
1096
457
