Tagged: ansys, autodyn-fragments, explicit-autodyn, impact-analysis
March 1, 2022 at 6:44 am
Vasim
SubscriberCan the number of fragments generated in explicit analysis in Ansys Autodyn for the impact analysis be calculated?
March 2, 2022 at 4:12 pmChris Quan
Ansys EmployeeThe Fragment Analyzer is only available in ANSYS Autodyn Component System or Autodyn Standalone. It is not yet available in Explicit Dynamics Analysis System in Workbench.
If you have solved the model in Explicit Dynamics system already, you can use Autodyn Component system to load the results from the Explicit Dynamics system and then conduct fragmentation analysis using Fragment Analyzer in the Autodyn system.
March 3, 2022 at 6:55 amVasim
SubscriberThanks a Lot.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
