Ansys Free Student Software
Free edges rectangular plate
    • Ochuko Ologe
      Hi, how can I get a link on how to get the natural frequencies of a rectangular thin plate with all edges free please?
      Thanks
      Ochuko
      If it's not covered in the Learning section you may find there's something in the Help system. Remember to anchor the plate to something or your simulation will see it fly away rather than oscillate!
    • Ochuko Ologe
      I dont need to anchor the plate. All 4 edges of the thin rectangular plate are completely free
    • peteroznewman
      Use a Modal analysis and request 20 modes.  The first 6 modes will have near zero frequency and are called the “rigid body modes”.
      Mode 7 is the first bending mode of the rectangular plate.
    • Ochuko Ologe
      Thanks Peter but the results from ansys could not validate the matlab results. Why the hug difference between matlab and ansys results with regards to free edges rectangular plate. Please guide me.
    • peteroznewman
      Please share the matlab inputs, equations and results and the ansys inputs and results.
      Have you used an analytic solution?
    • Ochuko Ologe
    • Ochuko Ologe
    • Ochuko Ologe
    • peteroznewman
      What geometry did you use?  A solid model?  Did you mesh that with solid elements?  If so, you only have 1 element through the thickness. This is not recommended for thin-walled structures.
      Use SpaceClaim to create a Midsurface to replace the Solid. Mesh that with shell elements. See how much that moves the first mode frequency.
    • Ochuko Ologe
      Thanks so much for your directives. I have finally gotten it.
Viewing 10 reply threads
