June 3, 2020 at 10:13 am
stefan.kuenzli
SubscriberHello
I have a problem with a large assembly, where I would like to do a Free-Free Modal analysis.
2020 R1
I only want to analyse a sub-assembly from the whole assembly. Therefore, I just defined the desired bodies as Simulation Bodies. I get wrong results (3.63e-2 Hz / rigid body modes).
However, if I delete the unneeded bodies, I get correct results (15.6 Hz).
In Discovery 2019 R3 I get the correct results in both cases.
Can you please have a look into this behavior? If needed I can provide the geometry files (not publicly)
Thanks Best regards
Stefan
June 3, 2020 at 11:40 am
Subashni Ravichandran
Ansys EmployeeHello skuenzli
I'm unable to reproduce this on an arbitrary assembly. Could you please share your model with us?.
I have shared an Ansys Secure Transfer link to you via email. Please use the link to securely transfer the files to us.
June 26, 2020 at 7:48 am
stefan.kuenzli
SubscriberHi Subashni
I sent you the files. Were you able to reproduce the behavior?
Best regards
June 26, 2020 at 8:36 am
Naresh Patre
Subashni is on sick leave for a couple of weeks. Will it be possible for you to send the file again? I will send you a new secure transfer link. Apologies for the inconvenience and delay.
June 29, 2020 at 8:03 am
Naresh Patre
Thanks for sending the files. It appears to be an issue with this model in 2020R1. However, I tested in the upcoming 2020R2 and couldn't reproduce the issue. So it looks like the issue has been fixed in the upcoming version.
June 29, 2020 at 10:04 am
stefan.kuenzli
SubscriberHi Naresh
Thanks very much for your investigetion and good to know that it is not an issue in the upcoming version.Best regards
Stefan
3930
2649
1861
1272
610
