Frequency dependent Damping ratio in Harmonic Analysis
    • msinghal623
      I have a multi-material structure and on this structure I have done undamped modal analysis. Now I want to do mode-superposition harmonic response analysis on the same structure. For one of the material in the structure I have the frequency dependent damping ratio.
      Is is possible to put the frequency dependent damping ratio for one of the material for mode-superposition harmonic response analysis.
    • Laurentiomoto
      Hi, did you find a way to do it? Im looking for this answer as welln
    • msinghal623
      You can use the MDAMP command during the harmonic response simulation. n
