November 17, 2020 at 7:59 pm
Hamad
SubscriberHellonnIs there any way to enter a permittivity that is a function of frequency in HFSS? And how?.Thanks. n -
November 18, 2020 at 9:21 am
rtk
Ansys Employee,nYes you can enter permittivity as a function of frequency in HFSS.nIn the edit material properties window, select Set frequency dependency and proceed as shown in the snapshot below:nnJust click on the Dataset blank cell to show the drop down menu. By this way either you can import a frequency dependent datasheet or can set frequency points as well.nHope this addressed your concern.nnBest Regards,nn
November 19, 2020 at 7:37 pm
Hamad
SubscriberHello rtk,nnThank you so much. I appreciate your help.Regards,n
- The topic ‘Frequency-dependent permittivity’ is closed to new replies.
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1688
1478
