3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Frequent crashes Ansys SpaceClaim after closing documents
    • paul
      A couple of customers are having issues regarding closing of designs in Ansys SpaceClaim. After opening documents and closing them, SpaceClaim freezes and does not repond anymore. The customers have to forcefully close the program and restart it. This problem appeared in the more recent releases of Ansys SpaceClaim.
      We did a fresh install of Ansys SpaceClaim, but this did not work.
      I have received a couple of logfiles from a customer, but i cannot attach them to this post.
      Any ideas on what the cause could be? If you need more information, please let me know.
    • dan
      We are having the same problem.
    • Roberto
      I have also reported this problem since the SpaceClaim 2023R1 version was released, there are problems with slow opening of assembly files and crashes.
      The problem regarding crashes was solved in part (not for all) by carrying out these operations.
      Please uninstall SpaceClaim.
      Then, delete any SpaceClaim folder that exists in C > Program Files.
      Then, go to the Registry Editor (type Regedit in the Windows search)
      In HKEY_CURRENT_USER > Software, delete any SpaceClaim folder.
      In HKEY_LOCAL_MACHINE > Software, delete any SpaceClaim folder.
      Delete any ansys SpaceClaim folder in C: and AppData
      Then, turn off firewalls (including windows firewalls) and antivirus.
      Then, re-install SpaceClaim. Make sure to run the installer as administrator (right-click run as admin)
      Regards
    • Roberto
      Check that the PCs have administrator rights
    • dan
      Thanks Roberto,
      We will give this a try next week when we update to 2023 R2
    • Roberto
      Hello
      I report the continuation of crashes when closing assembly files with a few components, starting from 50 components already
      Regards
Viewing 5 reply threads
