December 1, 2022 at 6:33 am
tamer elsayed
Subscriberi am simulating a friction stir spot welding process which includes a large deformation and modification of the contact and mesh shape
i am applying a rotational speed on the cylindrical tool, after trying all ways, the tool didn't rotate, which lead to incorrect simulation, and accordingly, reduce the frictional heating and reduce of the volume loss due to weari feel that there is some conflict between the element or contact type that i used with the rotation command, but after my extensive study, i know that the element type and contact type used are mandatory to perform the process
also, i tried using cylindrical joint instead of rotational velocity, or remote displacement with y rotation, but also not workingany help to let the tool rotate
December 9, 2022 at 4:58 pm
John Doyle
Ansys EmployeePerhaps you could try this in 2D and apply rotational velocity is similar way as demonstrated in Chapter 43 of the R2022-R2 WB Showcase Example Problem. Use many time increments and sufficently fine mesh.
- Workbench error
- Workbench not opening
- License Error
2564
2078
1289
1106
459
