September 5, 2019 at 5:49 am
lincs2k9
SubscriberI attached a screenshot from ansys workbench engineering data section. I need those parameters' value to analysis shape memory effect of Nitinol. Actually I don't understand those parameter. Can anyone help me in this issue?
=Shape Memory Effect
-Hardening Parameter
-Reference Temperature
-Elastic Limit
-Temperature scaling parameter
-Maximum Transformation strain
-Martensite modulus
-Lode dependency parameter -
September 5, 2019 at 11:41 am
SubscriberOpen the ANSYS Help system. In the search field, type nitinol. You will find the Technology Demonstration Guide > Chapter 40: Shape Memory Alloy (SMA) with Thermal Effect.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
