TAGGED: ansys-cfd, ansys-cfx, fluid-thermal-solid-interaction, fsi
September 28, 2023 at 9:18 am
dimitri.hamelin
SubscriberDear all,
I am actually facing a problem. I can not execute my Fluid/Solid Interaction.
Here is the warning I have before the error occurs: (I use a steady-state thermal analysis and a steady CFX problem, I say that because I saw for others the error occurs when the time staps were not the same)
| Warnings were found during data model validation. |
| Warning: Participant Steady-State Thermal (CouplingParticipant:Solution 12) |
| has the ExecutionControl 'Option' set to 'ExternallyManaged'. System |
| Coupling will not control the startup/shutdown behavior of this |
| participant. |
| Warning: Participant Fluid Flow (CFX) (CouplingParticipant:Solution 13) has |
| participant. |
+-----------------------------------------------------------------------------+Couls someone help me please ?
September 28, 2023 at 8:01 pm
Federico Alzamora Previtali
Ansys EmployeeHello Dimitri,
these warning may not be related to the actual error. Can you share the error message instead?
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8832
4658
3159
1688
1482
