February 20, 2022 at 12:15 pm
Husseinbarzegari
SubscriberHi guys I'm simulating a FSI model ( with ansys workbench 2020 R2 system coupling ) it's completely like a balloon inflating but it has some little differences for example a thicker solid part and water liquid as fluid
February 21, 2022 at 11:58 amHusseinbarzegari
Subscriberwhole end time 0.33 s in some iterations i considered it 0.5 s too.
March 7, 2022 at 2:50 pmStephen Orlando
Ansys EmployeeFor this problem instead of coupling Fluent and Mechanical, I recommended doing the entire simulation in Mechanical with hydrostatic elements for the fluid. A mass flow fluid inlet can even be defined in Mechanical. Mechanical obviously won't solve the Navier-Stokes equations, but the fluid pressure will be calculated from an equation of state.
Steve
March 9, 2022 at 9:21 pmHusseinbarzegari
SubscriberHi @Steve and thanks for your response but i have to solve this problem in fluid dimension too because of my master proposal topic (I study in subbranch of fluid engineering ), but do you know why these things happen to the system exactly ( i mean the odd situation of mass inlet versus system volume)? and can you please explain more about solving the problem only in Mechanical as you said above ?
March 10, 2022 at 9:29 amHusseinbarzegari
Subscriberthanks for your response, but i have to solve the simulation in fluid dimension too ( my master proposal is also about analyzing the fluid part ) and do you know why these things happens to the system ( I mean the odd situation of mass inlet versus system volume )? and can you please explain more about simulating in Mechanical part alone ?
March 10, 2022 at 9:50 amHusseinbarzegari
Viewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- Changing of font size
- System Coupling
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- 3D ROM in workbench
- Error message “Solver pivot warning” due to element birth and death
- ANSYS Direct Optimization
- HARDWARE COMPATIBILITY
- System Coupling
- When I open the Electronic Desktop, Twin Builder auto opens
2524
2066
1279
1096
457
