August 25, 2019 at 7:25 pm
nikos
SubscriberHello I am running a coupled analysis of Fluent and Transient Structural for simulating sloshing of a fluid in a tank.
Pics show the mesh of the fluid body and the dynamic zones created for the model. There are two fluid-structure interface regions, the lower is between tank and water and the upper is between tank and air.
Smoothing and Layering are checked in Dynamic Mesh (see pics).
I would like some help regarding the dynamic mesh and what the optimal settings could be because I am running a lot into the "negative cell volume detected" error and in general the sloshing is not so apparent and effective.
I also tried to make use of the cell height setting, under Meshing Options as well as the Solution Stabilization (see pics) but I need to find some definite way to use this settings effectively.
Thanks for any input on the problem. -
August 25, 2019 at 7:29 pm
August 29, 2019 at 10:41 am
Ansys EmployeeIf you search for "negative volume" you'll find the general solution is to decrease the time step.
February 29, 2020 at 10:11 am
FlorianHenscheid1
Subscriberhello nikos, I edit the same for my master work. I wanted to ask if you could solve the problem and possibly help me?
regards florian
February 29, 2020 at 2:11 pm
FlorianHenscheid1
SubscriberI have the same problems as you or maybe even more. For me, the lower fluidity (water) does not even move. Also, I don't know which model to use for the two fluids. I think you would have to do a VOF. So that the water gets into a Sloshing movement.When I tried two FS interfaces of the fluids to pair with the FSI of the solid, an error message also came, so I could not have expected these settings any further.
regards Florian
March 2, 2020 at 4:23 pm
Ansys EmployeeRead up on the VOF model. Why would you need two interfaces to pair up the fluid & solid zones?
May 2, 2020 at 12:14 am
bilalben
SubscriberHi Sir
can you provide me with tutorials on liquid sloshing
2656
2120
1345
1118
461
